Cần hướng dẫn tải và cài đặt 1 số ứng dụng ...
linhbs
Thân chào 2 anh. Mình là bác sĩ nhưng rất đam mê công nghệ thông tin. tình hình là như thế này:
Em vừa mới mua con Nexus one em thấy pm skyscape on android này hay quá, em cài hoài mà k được. E nhờ anh Quang và anh Wildcat hướng dẫn dùm em. E thành thật cảm ơn 2 anh nhiều.
Skyscape Medical (all versions)
Requirements: Android
Overview: Skyscape is pleased to provide hundreds of trusted medical resources for the Android (Google) devices.
To use: (use only if medical emergency)
- Install reader on device (if not already installed).
- Run KeyServer on your PC.
- Check products you want (including any already installed, otherwise the reader will remove them).
- Choose options you want:
- "Send reader updates" - tell the reader about latest known (from data file) version of the reader.
- "Force download server to this host" - tells reader to download from this host, instead of real server (from data file).
- "Force download path to '/download/<file.ext>' - if downloading from this host the path is shortened so you put the files directly in download directory, no need to create the full directory structure used by real server.
- "This hosts IP" - the ip address that the DNS server will send to the reader, also used for downloads (if option above is used).
- "Enable DNS server" - enable a DNS server that sends this hosts IP when reader requests server address. Configure device to use this host as your DNS server instead of normal DNS server, no need to modify hosts files then. If you do not use DNS server you will need to modify your /etc/hosts file, or modify entries in your real DNS server (see XML for which hosts are needed).
- Launch reader on device.
- Update reader resources: Tools -> Update Resources
- When prompted for username and password use anything you like.
- Do not connect to real server after using (firewall?).
To update data file:
- Look at XML, understand.
- Get version numbers from windows trial version/other users/etc.
- Work out new download url, download it and check sizes.
- Update xml.
Thanks to Xer0 for English translations.
Important:
Read instructions!
You must enable tools DNS server (and change phone settings to use it) or modify your hosts file/DNS server.
If you don't know how to operate your phone, change network settings, etc. do not post here - find android forum instead.
More Info:
Code:
http://www.skyscape.com/
Download Instructions:
http://rapidshare.com/files/379528995/KeyServer-v1.2.0.rar
Nguồn: http://forum.mobilism.org/viewtopic.php?f=425&t=96981
Đăng nhập skyscape.com
usename: thuclinh2005@yahoo.com
pass: 832201
Nếu có tài khoản của skyscape rồi thì login trực tiếp vào skyscape từ trình duyệt browser rồi down trực tiếp trên đt luôn.Từ điển chuyên ngành y này không rành nhưng trang chủ có hướng dẫn cài đặt cho Androi đó,lấy hướng dẫn cài đặt này về xem nha :D
Rất cám ơn bạn trả lời. Phần skyscape free thì mình cài được còn phần cr@ck của tác giả rab trên skyscape on android cần hiểu về server và client bạn à.
Có ai giúp mình k cám ơn nhiều nhiều lắm.....
Trên pc của mình nó chỉ có hình ảnh như thế này.
Nếu làm đúng thì như thế này
Có ai giúp mình, mình vô cùng cám ơn. Cám ơn rất nhiều( Mình đã làm gần 1 tháng rồi nhưng k thành công).
Rất muốn giúp bạn nhưng hiện tại N1 của mình đã bị anh bạn trên Hà Nội cướp mất nên khg thể giúp được.
Chắc phải mua con khác thui.
