Thông tin về FW mới của 5800! 40.0.001???
vừa up lên 31.0.101 hy vọng từ từ hãy có fir mới.ko suốt ngày up fir thì mệt lắm :-? mà không bít con 5800 dùng có được 2 tháng ko.dạo này đổi đt nhiều tốn tiền quá:(
http://bugreports.qt.nokia.com/browse/QTBUG-4784
Device: Nokia 5800
Firmware version: 40.0.001
Release: 5695b50d
Platform: armv5 udeb
Compiler used: RVCT 2.2 build 686
Application: qmediaplayer
Launched from: application launcherarmv
Problem description:
Select 'Open File' and then select a video file. Watch the app UI in the period between the file dialog being dismissed and the video starting to play. Artefacts are visible as the app layout changes, and the video widget is consequently resized.
Similar artefacts are visible during full-screen transitions (both directions), and when screen orientation is changed.
This is a consequence of the use of the disableBlit flag in Phonon::MMF::VideoOutput. This is necessary in order for video to be visible, but at present, blitting is disabled too early - it should happen immediately before the MMF stack writes to the UI framebuffer.
[YOUTUBE]http://www.youtube.com/watch?v=SHdsfaerZbs[/YOUTUBE]
FW 40.0.001 cho 5800XM là của Qt phát triển. Symbian đã là mã nguồn mở rồi. Không biết Qt phát triển fw mới này để kinh doanh hay gì đây!? Tiếp tục hy vọng và chờ đợi vậy.
http://www.symbian-freak.com/news/0...novation_occurs_with_you_sergejs_cuhrajs.html
David Rivas also didn’t forget to praise the Symbian^4 as having the ‘mature’ and ‘deeply important’ Qt platform from Trolltech, that he described as ‘the best integrated platform for application development in the industry’. This was followed with the deeply confusing video, showcasing Qt apps running on what I recognized as Nokia 5800 and Nokia N95-1, with the later especially surprising me.
Qt 4.6 Beta 1 running on Samsung I8910 & Nokia 5800 Symbian S60 devices
[YOUTUBE]http://www.youtube.com/watch?v=uhr44p2p_3M[/YOUTUBE]
nếu có rồi chắc đè nhau up dữ lắm đây ...hoohoh có khi nào tối nay có . cái đập up liền cho nó sướng nhỉ ^^
Đây có phải là sự thật?
Haha! Trời ơi! Nổi cả da gà rồi! Sắp có FW mới! Chắc 1 tuần nữa là có up được thôi!
Nhìn FW mới này mà thèm rỏ dãi cả ra,thích quá,không biết đến bao giờ mới được dùng nhỉ
nếu như vậy thì đúng là có FW mới, nhưng có confirmed là có kinetic scrolling chưa mấy bác nhỉ?
Thành viên tombgo trên Daily Mobile chụp 2 hình fw này đang thực hiện quay lại để post lên Youtube. Các bạn hãy chờ nhé!
FW 40.0.001 chỉ là fw thử nghiệm cho các nhân viên của hãng test.
mình thầy màn hình của nokia 5800 ko to như n97 cho nên thiết kế màn hình như của 5530 là đẹp rồi. có widget nhìn có vẻ rối....
cái hình thứ 2 mình thấy thế nào ấy . gần giống như là PTS màn hình của n97 vao 5k8 hix . hình như cái kiểu màn hình này mình thấy có bài post roài . lâu lâu rùi :-? cái biểu tượng bàn phim ỏ giữa options va done không hợp lý lém . đấy là ý kiến của e . mong các bác thông cảm ^^
